Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: looking for a cabinet door
  1. #11
    Senior Member jbs's Avatar
    Aug 2015
    Issaquah, WA
    414
    Emailed Jerry, and he said it is a plywood that originally he was getting from East Teak in Sultan. He called them and they refereed him to Cross Cut in Sodo, and Home Builders center at 1110 W. Nickerson St. in Seattle. HBC will sell half sheets of plywood. I will have to get over to Seattle with a small sample to check out the suppliers for a match or close to match.
    Boat=Bust out another thousand
    1973 19' Glasply HT 140 Mercruiser- procrastinating ongoing rebuild
    1985 2200 Glasply HT Marauder 5 L
  2. #12
    thank you very much
    1980 2400 Cuddy I/O, 2017 Cummins 4BT coupled to a Volvo DP-SM with F9 Props, and a 2014 Mercury 15HP Pro-Kicker "LOOSE CHANGE"
