Results 1 to 2 of 2
Thread: 1978 GP 21 foot amp light
    Easy question --if the engine is running and the dash amp light is on --is generator producing current? Oil pressure light on = problems. Amp light on = what?
    Thanks,
    Mark
    my 23 has gauges so am not sure on the lights, but if you want to know if it is charging check the battery voltage running is should be in the 13 volt range
    1980 2400 Cuddy I/O, 2017 Cummins 4BT coupled to a Volvo DP-SM with F9 Props, and a 2014 Mercury 15HP Pro-Kicker "LOOSE CHANGE"
